Plug-in batteries come to hybrids
Nov. 8, 2007
Watertown, Mass.-based startup A123Systems thinks it has solved the problem of overheating in lithium-ion batteries.
The new development could lead to use of lithium-ion cells in hybrid vehicles.
Lithium-ion cells have a high energy density, which makes them candidates for use in hybrids. But concern over batteries catching fire limits their use.
Fires typically happen when a manufacturing defect (possibly compounded by overcharging) lets oxygen escape the cathode in a heat-releasing oxidation reaction. An overheated cell triggers oxidation in neighboring cells through a process known as thermal runaway.
Batteries from A123 use cathodes from iron phosphate, which bonds to oxygen better than the cobalt dioxide in conventional lithium-ion batteries. This makes cells less prone to oxidation and thermal runaway. A nanopatterning design that boosts the conductivity of the iron phosphate helps overcome the material’s relatively low operating voltage, says the company.
Make Contact
A123Systems, www.a123systems.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
