Julie Kalista
Online Editor
Inspired by geckos, researchers made a much larger device with each hair equipped with a small magnet at the end. When they all work together, they securely stick to steel and iron surfaces. Hundreds of small points of contact let the device work on rough or curved surfaces and can be removed by peeling, similar to the way geckos operate. Researchers hope this may be used in the development of surveillance or inspection robots for steel bridges, towers, and nuclear plants.
This web-only article appears in the Tech Insider e-newsletter. If you enjoyed this article and would like to read more like it, sign up today for our free e-mail newsletters!
