Washer Helps Assure Quick-Release of Shaft Collar
Nov. 2, 2015
The Elasto-Ring rubber washer cushions the U-Clip quick-release collar against any pressures.
When a U-Clip quick–release collar is used to hold a reel or spool on a shaft, it can sometimes get stuck as the spool flanges expand and create back pressure. The bulging flanges press against the U-Clip and interfere with the clip’s quick-release mechanism.
To prevent this, engineers at Amacoil Inc., Aston, Pa., developed the Elasto-Ring, a rubber washer that cushions the U-Clip against any pressures. The ring snaps onto the end of the U-Clip collar and absorbs any back pressure, making it easy to remove the ring and clip quickly using just one hand.
Elasto-Ring washers come in the same 10 sizes as U-Clip collars, ranging in diameter from 8 to 35 mm. Made of durable, heat-resistant rubber,  they are long lasting and do not deteriorate from heat generated by friction coming from the rotating spool flange.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
