The maintenance-free BMU brushless-dc motor and driver package offers a wide and stable speed range, easy wiring, and simple set up.
The all-new brushless motor — with a smaller overall size and increased efficiency — is coupled with an easy-to-connect and control driver. The units have an 80 to 4,000 rev/min speed range. When used with a parallel gearhead, up to 260 lb-in. of high permissible torque can be attained.
The motor/driver comes in 30, 60, or 120 W (1/25, 1/12, or 1/6 hp) and in round shaft or parallel-shaft gearhead.
Key features include easy to wire with motor connectors and driver connectors, and long-life gearheads are rated for 10,000 hr.
Oriental Motor U.S.A. Corp., 1001 Knox St., Torrance, CA 90502, (310) 715-3301
Safety Products Overview
Dec. 20, 2024
