Machinedesign Com Sites Machinedesign com Files Uploads Thumb Maxon Dg Dcx Motor
Configurable drive system
May 20, 2013
When combined, DCX motors, GPX gearheads, and ENX encoders form a high-precision drive system. DCX motors feature precious metal or graphite brushes, can be equipped with standard preloaded ball bearings or sintered bearings, and cover a large voltage range with six different ironless windings. Almost all mechanical configurations are possible with the motor’s new housing, and its mounting flange is fully configurable, including thread diameter, position, number of mounting holes, and dimensions of the centering collar.
When combined, DCX motors, GPX gearheads, and ENX encoders form a high-precision drive system. DCX motors feature precious metal or graphite brushes, can be equipped with standard preloaded ball bearings or sintered bearings, and cover a large voltage range with six different ironless windings. Almost all mechanical configurations are possible with the motor’s new housing, and its mounting flange is fully configurable, including thread diameter, position, number of mounting holes, and dimensions of the centering collar. A short-configuration motor without a flange is also available. The motor’s output shaft length and diameter can be selected, with or without flat.
A GPX22 gearhead, for use with the DCX motor, consists of individually configurable gear stages and a configurable flange. With a laser weld, the gearhead interface is joined seamlessly to the motor. The output shaft is available in different lengths, with or without a flat, and with cross holes or a key.
Two matching encoders, the ENX Quad and ENX Easy, feature a strong design and high signal quality. The ENX Quad is a single-pulse, two-channel encoder suitable for speed and direction detection. With a built-in ESD protection network, reverse-polarity protection, and cable strain relief, it is suited for simple closed-loop tasks. The ENX Easy is a three-channel encoder with line driver and a resolution of up to 1,024 pulses/rev. Cables are configurable in seven lengths, from 50 to 1,000 mm.
maxon precision motors inc., 101 Waldron Rd., Fall River, MA 02720, (508) 677-0520, dcx.maxonmotor.com; www.maxonmotorusa.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
