Machinedesign Com Sites Machinedesign com Files Uploads 2013 04 Iwis Dg Anti Ba Chains
Antibackbend chains - iwis drive systems LLC
April 29, 2013
Antibackbend chains, flexible in only one direction, are used for pushing loads and can bridge larger gaps without a guidance system. Applications include adjustable operation chairs, hospital beds, or mixing units for dental impressions.
The chains transmit tensile and compressive forces over longer distances without the need for a guidance system. Similar to linear drives, the units eliminate the need for an endless, circulating chain drive. The side and backbend capability is individually adjustable within certain limits. The chains can be made in various sizes, configured for application-specific drive concepts, and are available in various materials with a range of surface finishes and lubricants.
iwis drive systems LLC, 8266 Zionsville Rd., Bldg. 100, Indianapolis, IN 46268, (317) 821-3539, www.iwisusa.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
