Product spotlight: Brushless motors
Dec. 1, 2008
Slotless brushless motors 23 mm slotless brushless motors eliminate cog and allow precise positioning compared to conventional toothed motors. Features
Features & benefits
  • Available in 2 and 4-pole designs, sensorless or with hall sensors
  • Up to 176-W power output, 50,000 rpm, 90% efficiency
  • Engineered to provide a straight-line speed-torque relationship under all conditions
Koford Engineering
[email protected]
www.koford.com
Circle 151
Brushless dc motors
NEMA 17 brushless dc motors offer high speed and high dynamic torque.
Features & benefits
  • Quiet and smooth operation with optimal performance from 300 to 3,000 rpm
  • Suitable for applications with little power requiring a higher efficiency motor
  • Available in stack lengths of 1.61, 2.40, 3.19, and 3.94 in.
  • Produce up to 106 oz-in. of peak torque depending on stack length
Lin Engineering
(408) 919-0200
www.linengineering.com
Circle 152
Brushless servomotors
Fully integrated I2 brushless servo system includes a closed loop brushless dc servomotor, built-in drivers, controllers, and I/O devices.
Features & benefits
  • Runs on universal power anywhere in the world with no external power supply
  • Test and program in less time than other motion control systems
  • Menu-driven procedure for programming velocity or position commands accomplished by filling in desired values on the Wizard host software setup screen
  • Can interface to any input or output device with the click of a mouse
  • Easy to follow fill-in-the-blanks menu for analog command setup
Specialty Motors Inc.
(800) 232-2612
www.specialtymotors.com
Circle 153
Brushless dc motor
EC-powermax 22 achieves extremely high torque at slow speeds compared to similarly sized brushless dc motors.
Features & benefits
  • Available in two lengths with an operating range of 90 to 120 W
  • Easily combined with 32 mm planetary gearheads
  • No detent because grooveless stator exhibits excellent control characteristics
maxon precision motors inc.
(800) 865-7540
www.maxonmotorusa.com
Circle 154
