Stainless steel bellows couplings
Precision couplings Flex B and Flex K provide excellent kinematic properties with three types that offer different combinations of stiffness, radial compensation, and axial motion for high-end servo drives.
Features & benefits
High torsional stiffness for drive systems requiring high torsional integrity
High positional accuracy, low risk of resonance
Three or nine convolutions, or two convolutions with cardan, for different shaft alignments
Flex M disc-type precision coupling available for high rotational speeds and motion integrity
Huco Dynatork
Altra Industrial Motion
(888) 999-9860
www.huco.com
Circle 151
CD couplings
A special coupling design features a CD disc that has high torsional stiffness, yet allows for misalignment in high-stress applications.
Features & benefits
Using finite element analysis, the CD disc can be easily modified along with changes in composite material
Custom disc designs (manufactured on laser cutting machines) can add to or lessen coupling flexibility or increase strength and stiffness
40 standard CD coupling models and sizes to work from; custom couplings are configured much faster than couplings using all metal components requiring special dies and tooling
Zero-Max Inc.
(800) 533-1731
www.zero-max.com
Circle 152
Precision couplings
Servomax precision couplings are designed to handle 10,000,000 cycles at rated torque.
Features & benefits
Polyurethane insert damps vibration and absorbs slight shaft misalignment in lateral, axial, and angular directions while transmitting backlash-free torque
Where failure is a possibility and ease of maintenance critical, the EKH series allows easy installation and removal without disturbing motors and gearboxes; handles torque ranges from 15 to 19,000 in.-lb.
Three different insert hardness levels allow choice between torsion resistance and flexibility levels
R+W America
(630) 521-9911
www.rw-america.com
Circle 153
Flexible beam couplings
Zero-backlash beam couplings are machined from a single piece of aluminum and feature multiple spiral cuts to provide high torsional stiffness and torque capabilities.
Features & benefits
Multiple spiral cuts accommodate angular and parallel misalignment, as well as axial motion
One coupling series features two sets of three cuts, suitable for light-duty power transmission applications, such as coupling a servomotor to a leadscrew; the other series features two sets of two spiral cuts and is designed for precision applications
Aluminum or stainless steel; 20 body sizes available with ODs from 10 to 38 mm and bores from 2 to 19 mm
Ruland Manufacturing Co.
(508) 485-1000
www.ruland.com
Circle 154
