Floating Shaft CD couplings provide a torsionally stiff, zero-backlash option for connecting long distances between shaft ends.
Features & benefits
Flex element made of composite material simultaneously allows high torsional stiffness and low bearing loads
Custom designs available: Torques from 270 to 550,000 in.-lb; speeds from 500 to 15,000 rpm; lengths from 46 to 196 in.; hub ODs from 2.25 to 12 in.
Spacer materials include aluminum, steel, stainless steel, and titanium; custom finishes and several hub options available
Zero-Max Inc. (800) 533-1731 www.zero-max.com
