Chainflex CF7 and CF8 power and control cables have short-pitch conductor twisting for long life. Suitable for high-flex applications, the cables feature a low-adhesion, PUR-blend outer jacket and are oil and coolant resistant as well as flame retardant. The cables operate at temperatures from –4 to 176°F and have a minimum bending radius of 71⁄2
3
the outer cable diameter. CF8 cables are equipped with a high-coverage shield (90% optical). The cables are bundled rather than layered for a uniform bend radius across each conductor. More than 20 different sizes and five awgs are available. igus Inc., Box 14349, East Providence, RI 14349, (800) 531-2747, igus.com
Jan. 10, 2025
Jan. 10, 2025
