Bellows-Comparison_Infographic feature
Comparing Electrodeposited Bellows to Edge Welded Bellows
Oct. 16, 2017
Sponsored by Servometer
Not all metal bellows are created equal. Some have higher life cycles than others. Some are better suited for lower temperatures while others are more sensitive to pressure. Is an electrodeposited bellows the best choice for your job or application or should you pick an edge welded bellows? Learn about 13 key performance factors that we call “bellows basics” and that you should consider when making a selection in this illustrated infographic.
