Convert pressure, mechanical, vacuum and temperature changes into linear or rotational motion using metal bellows. It may be the smallest component of an overall machine assembly but it very often plays the most critical role in the functionality of a system. This newest whitepaper from Servometer outlines seven key enabling technologies that benefit from bellows across a wide range of engineering applications – providing a more precise, more reliable or less costly alternative to an existing engineering solution.
