Hydraulic Work Supports Achieve High Performance
June 23, 2016
Automatically adjusting hydraulic work supports developed by Carr Lane Roemheld come in spring-, fluid-, and air-advanced versions.
Carr Lane Roemheld offers a wide range of hydraulic work supports that automatically adjust to the workpiece height, then lock securely to become fixed rests. Available in spring-advanced, fluid-advanced, and air-advanced types, these work supports are extremely compact, starting at just 1 in. diameter, with maximum pressures up to 7500 psi. The high-performance supports, which are designed for 500,000 cycles, come in more than 60 different standard sizes and styles, with supporting forces from 145 to 23,000 lb. Added features include contact bolt o-ring sealing, stainless-steel internal parts, and a metal wiper on the exterior.
For more information contact Carr Lane Roemheld Mfg. Co., 927 Horan Drive, Fenton, MO 63026, 1-800-827-2526, or click "CNC Machining" at clrh.com.
Looking for parts? Go to SourceESB.
