It resists EMC and polarity protected with reliable switching points and fast response times. Its sensing face is in front of the sensor to help it detecting pistons in short-stroke cylinders. The sensor comes with a quick-mount tab that helps seat the sensor in the cylinders groove, making single-handed mounting possible. And the screw has been moved away from the cable-end, providing cable strain relief while ensuring the sensor remains in place if the cable is pulled.
Turck Inc., 3000 Campus Dr., Plymouth, MN 55441, (763) 553-7300, www.turk-usa.com
Dec. 23, 2024
Dec. 23, 2024
