In-line flow controls
Feb. 11, 2014
PQ-FV in-line flow controls use a tube-to-tube connection that can be installed as a meter-in or meter-out device. The PQ-C elbow controls are for lightweight applications when mounting directly to an NPT port on a cylinder or valve is required.
Intake air in meter-out versions flows freely through the flow control; exhaust air is metered out through an adjustment screw. With the meter-in style, air is metered in through an adjustment screw; exhaust air flows freely. Control is varied through a finely threaded adjustment screw.  A locking nut is provided so it can be secured in its final setting.
The controls are available in 25 different models: #10-32, 1/8, 1/4, and 3/8-in. NPT.
Clippard Instrument Laboratory Inc., 7390 Colerain Ave., Cincinnati, OH 45239, (877) 245-6247, www.clippard.com/link/md1293887
