Machinedesign 7071 Mdwhitepaper 7
Trust but Verify: the Value of Acceptance Testing
Aug. 4, 2015
Sponsored by Kaydon
Acceptance testing helps designers choose the right bearings for applications with narrow performance windows. Since the engineering data in bearing catalogs is typically derived from calculations and based on nominal dimensions, relying on it without verification can be a gamble in critical applications. A new white paper from Kaydon Bearings, an SKF Group company, explains when to use acceptance testing and how to develop an Acceptance Test Plan (ATP) to check key attributes, such as roundness, ring runout, face offset, and friction torque.
May 7, 2024
May 7, 2024
May 7, 2024
