Machinedesign Com Sites Machinedesign com Files Uploads 2013 04 Cooper Dg 01 E Bear
Split-roller bearings - Cooper Split Roller Bearing Corp.
April 29, 2013
Fully interchangeable with the company’s 01 and 02 Series bearings, the new 01E (medium-duty) and 02E (heavy-duty) split-roller bearings provide up to 29% more radial capacity and 16 to 90% more axial-load capacity.
The bearings are completely split to the shaft, eliminating the need to disassemble all components on a shaft for service or replacement, and significantly reducing downtime. The bearings are available with bore sizes from 6.5 to 12 in. Typical applications include mining equipment, industrial fans and conveyors, and power generation.
Cooper Split Roller Bearing Corp., 5365 Robin Hood Rd., Suite B, Norfolk, VA 23513, (757) 460-0925,
www.cooperbearings.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
