Centralized lubricating systems lubricate all the friction points from a single pump source. The pump can be manual, mechanical, or motor operated. Positive pressure controls the flow rate and also provides a means of indicating correct operation or malfunction. Also, these systems can shut down a machine if required.
Aug. 29, 2024
Aug. 28, 2024
