3437523 © Mlan61 | Dreamstime.com
Electric motor
Are Outdated Motors Draining Your Fluid Lab’s Potential?
June 5, 2025
Those legacy systems still function, but they are not a guarantee of optimal efficiency. Upgrading to advanced motor systems can enhance performance and provide many benefits.
Precision, dependability and control are essential in fluid labs. Yet, many laboratories continue to use aging motor technologies that cannot meet the demands of today’s tightly regulated and highly automated systems. These legacy systems may still function, but they are often a source of performance inefficiencies and wasted energy. As fluid labs move alongside advanced manufacturing and diagnostic needs, modern technologies offer a critical opportunity for higher throughput and improved overall system performance.
The Hidden Costs of Outdated Motors
At first glance, an older motor still doing its job may not raise immediate concern. However, precision and efficiency are nonnegotiable in fluid labs, and the long-term costs of outdated motor systems can quietly erode productivity and drive expenses.
Consider pumping stations, which are integral to fluid handling systems in lab settings. Studies found that electricity is the primary operating cost for pumping stations, accounting for approximately 40% of their total energy use. When powered by aging motors, these systems draw even more energy than necessary, leading to substantial inefficiencies.
READ MORE: Support for Roboticists: Maxon Motors, Actuators, Drives & More
Old motors often operate at fixed speeds or lack the efficiency of newer models. Most of the time this leads to higher power usage, especially in variable load applications.
Some of the other costs associated with outdated motors include:
  • Frequent maintenance and unplanned downtime. Wear-and-tear from inefficient operation increases maintenance frequency, making aging components more prone to sudden failure.
  • Inconsistent performance and reduced precision. Fluctuating output or delayed responsiveness in older motors can compromise accuracy in fluid handling, especially in systems that require precise control flow or temperature stability.
  • Incompatibility with automation and monitoring systems. Legacy motors often lack the feedback capabilities or communication protocols to integrate with modern lab automation, limiting visibility into system performance.
  • Higher life cycle costs. While the upfront cost of replacing a motor can be steep, continued operation of an outdated unit leads to compounding energy, labor and process efficiency losses over time.
Understanding these hidden expenses is the first step toward evaluating whether motor upgrades could achieve greater efficiency and control.
Maximizing a Fluid Lab’s Potential with Modern Motors
The latest motor technologies are more than incremental improvements — they are fundamental to improving fluid labs’ operation. By replacing outdated motors with advanced systems, research facilities can greatly enhance energy efficiency and system reliability.
Sustainability is one area where these upgrades can make a tangible impact. For instance, a health sciences facility modernized its purified water system to improve department adaptability and resource use. The system now supports variable output and remote control — capabilities often powered by motor and pump systems with integrated speed and feedback control.
READ MORE: Big Power in Small Packages: The Revolution of Micro-Sized Servo Drives
As a result, the facility reported greater energy efficiency and performance, with an annual savings of 1.2 million gallons of water. Modern motor-driven systems promote these gains by reducing energy use. Therefore, labs can reduce their carbon footprint, helping them meet sustainability targets and compliance benchmarks.
Modern motor systems can offer many other benefits:
  • Dynamic process optimization. Variable speed and torque capabilities allow motors to respond quickly to changing system demands, minimizing lag and overshoot in sensitive fluid operations.
  • Greater design flexibility. Compact and modular motors enable space-saving configurations so engineers can optimize lab layouts for functionality and cleanliness.
  • Real-time monitoring and feedback loops. Motors embedded with sensors and diagnostics facilitate adaptive control, which automates responses and reduces reliance on manual calibration.
  • Streamlined multi-system coordination. Enhanced compatibility with automation platforms ensures seamless system integration.
Key Motor Technologies for Fluid Labs
As fluid labs grow to meet higher precision and scalability demands, motor selection is key to system performance. The most relevant technologies for modern fluid handling include the following.
Brushless DC Motors
Brushless DC motors are a staple in fluid labs due to their high efficiency, long operational life, and precision control over speed and torque. They are especially useful for fluid dispensing systems, robotic automation, and tasks that require low maintenance and consistent performance. Additionally, these motors are applicable in surgical robots. Because of their high precision, they enable doctors to use robotic limbs in complex surgeries where minimal tissue damage and blood loss are key.
However, one design consideration is that they can experience losses, primarily from copper and iron, and especially under continuous or high-load conditions. While these losses are minimal in most lab-scale operations, they can become more noticeable in high-speed functions.
Microhydraulic Actuators
These are gaining traction in microfluidics and lab-on-a-chip platforms. Microhydraulic motors allow controlled fluid movement in extremely small volumes, enabling advanced experiments with reduced reagent consumption. Their compact design also supports miniaturization without sacrificing responsiveness.
READ MORE: Human-Centric Robotics: Choosing Motor Solutions
Brush DC Motors
Although less efficient than brushless alternatives, brush DC motors still have a place in simpler lab applications. Their low cost and easy control make them useful for tasks for low-end precision or portable lab devices.
Stepper Motors
Stepper motors operate with accuracy, repeatability and ease of control, making them ideal for syringe pumps or automated dispensing machines. They offer precise, incremental motion without complex feedback loops, simplifying integration in cost-sensitive environments. Since they are reliable in position and control motion, they make a common choice in fluid lab equipment, where consistent sample handling is essential for test accuracy.
Piezoelectric Motors
Piezoelectric motors are used in precision dosing and micropumping systems, enabling the highly accurate control of small fluid volumes. Their compact, non-magnetic design is also beneficial in environments where electromagnetic interference must be minimal.
Taking a System-Level Approach to Motor Upgrades
Upgrading a motor in isolation may yield incremental benefits. However, to gain the full potential of a research facility, it is essential to evaluate the entire system. Motors interact with pumps, valves, drive sensors and control software, so taking a system-level approach ensures compatibility and maximizes efficiency. It also avoids introducing new inefficiencies elsewhere in the process.
One of the most common oversights in lab upgrades is failing to assess how a new motor interfaces with existing control systems. Modern components often rely on digital communication protocols for real-time monitoring and adjustment. If the rest of the system cannot respond to the motor’s feedback, the lab misses critical capabilities like closed-loop control.
READ MORE: Motor Control Solutions for Humanoid Robots
It is also important to consider the mechanical and operational context of the upgrade. For example, if a lab upgrades to a variable-speed motor, the downstream components must be rated to handle fluctuating flow rates and pressures. Otherwise, the performance gains could decrease due to inconsistent system behavior.
Engineers should conduct a full compatibility and interoperability audit before implementing motor changes. This includes reviewing:
  • Drive electronics
  • Software control interfaces
  • Environmental constraints
  • Mechanical aignment
Upgrading motors with a system-wide perspective prevents costly oversights while creating a more scalable, efficient fluid handling ecosystem.
Powering Precision and Progress with Smarter Motor Systems
Outdated motors may still be functional, but they limit what a fluid lab can achieve. Rather than operating a facility on limited efficiency, upgrading to advanced motor systems can offer higher responsiveness and flexibility. Therefore, engineers must consider integrating these newer technologies to achieve higher throughput and tighter control.
Emily Newton
Emily Newton
Emily Newton is a technology and industrial journalist. She is also the editor in chief of Revolutionized. She has over five years covering stories about warehousing, logistics and distribution.
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
