Industrial robot
Batteries Not Included: Why You Shouldn’t Ignore Robot Batteries
Sept. 21, 2018
Michele Windsor, global marketing manager at robot battery specialist Ultralife Corporation, explains the impact poor design and integration of batteries can have on industrial robots.
One of the key reasons for using an industrial robot to automate a process is to improve product quality, through increased reliability and accuracy. But for robots to be truly reliable and safe, engineers should ensure they have the correct power solutions.
In a survey conducted by the journal Science Robotics, researchers revealed that power and energy sources represent one of the most challenging areas of robotics research. With a multitude of potential applications, this is particularly important for robots operating outside the confines of a cage, untethered from an electrical outlet and working alongside human employees.
For instance, autonomous mobile robots and automated guided vehicles—such as Omron’s series of LD self-navigating autonomous intelligent vehicles and Kuka’s KMR series of mobile robots—have become commonplace sights at trade shows and in industry. Because they can’t constantly connect to a power supply like a traditional industrial robot, their power requirements are far more complex.
The report continues: “Beyond the currently available commercial technologies such as lead-acid, nickel-metal hydride, and lithium-ion batteries, there has already been extensive research on developing next-generation technologies such as fuel cells and supercapacitors.”
Losing it All
If any robot—collaborative, mobile or traditional—were to lose power mid-application, it could have a devastating effect. For industries such as food and beverage or pharmaceuticals, downtime can result in loss of product and profit. For robots in the medical sector, loss of power could result in surgeons having to operate manually, which may not be as accurate, in turn increasing potential risk. More likely, it would result in the surgery being cancelled.
In addition, power failure can also mean a robot loses calibration and mastering values. Calibration establishes the parameters in the kinematic structure of a robot, such as the position of its joints, tool-center-point (TCP) positions and joint lengths.
Knowing its Origins
A robot’s origin position is a vital part of the set-up process because it instructs the machine on what position it should return to when it rests. The memory for where each axis should be is stored in the robot battery. Without the position, every path trajectory will be off, resulting in inaccurate actions that can damage equipment or even hurt nearby workers.
If the battery fails mid-process, the operator must reprogram the robot’s origin position before restarting the application. Retraining can take a considerable amount of time to ensure all axes are aligned correctly, resulting in further production downtime.
To avoid the need for re-programming and retraining, operators should ensure that the robot returns to its origin position when it powers down. This means that should the battery fail during start-up, the robot is already in its origin position.
Addressing Power Needs
As robots become increasingly more intuitive, their power demands also become significantly greater. To complete more complex tasks, robots may be fitted with an array of sensors to detect variations in light, sound, temperature, and distance. Each of these sensors places a greater demand on power, meaning a more effective solution may be required.
When considering potential battery options for your robot, there are several options available. However, Li-Ion (lithium-ion battery), Li-Poly (lithium polymer), and NiMH (nickel-metal hydride) are normally considered to be the most suitable for robots with high power requirements.
While industrial robots continue to improve productivity, competitiveness, and overall process automation, if they are not supplied with adequate power manufacturers, they could face additional problems. When a design engineer or systems integrator begins work on a new robot project, he or she should consider power supply at the outset to ensure that the project bears fruit in the way the end user would want.
June 27, 2025
June 25, 2025
June 25, 2025
