Electronic Latch Reads Multiple Credential Formats
April 13, 2017
The "Swinghandle" latch features an RFID smart-card reader armed with a variety of credentials that enhances security and adaptability.
The H3-EM Electronic Locking Swinghandle from Southco, Concordville, Pa., features the same intelligent electronic locking and monitoring features as the standard H3-EM Series. But it also has a built-in multi-class RFID reader compatible with a variety of RFID credentials, along with both 125 kHz and 13.56 smart-card-based credentials.
The HID SE smart-card reader supports several readers so it can provide a higher level of security and simplify the process of transitioning to new security technologies used to manage access to keyless entry points at the equipment level.
The latch also sports LED indicators that quickly give technicians a visual status on equipment access, and credential-read status. The latch is attached using simple, single-hole panel preparation compatible with industry-standard enclosures for OEMs and field retrofits. When connected to an access control system, the latch lets users easily track and record access to the electronic locks, providing an audit trail that can demonstrate compliance with regulatory requirements.
Granite Motion Systems for Precision Automation
Feb. 7, 2025
PI Granite Based Motion Systems. We provide custom Engineered Multi-Axis Precision Automation Systems, built to your specifications– quick turnaround
Feb. 7, 2025
Flexible Multi-axis Granite Motion System for System Integrators and Machine Builders
Feb. 7, 2025
PI’s X-417 multi-axis positioning system / multi-axis stage is a granite motion system for high speed, high precision automation. Preconfigured with a granite base and EtherCat...
Laser Beam Steering Solutions, Fast Steering Mirrors
Feb. 7, 2025
Fast Laser Beam Steering Mirror (FSM) | Piezo Steering Mirrors | Voice Coil | Tip/Tilt Mirrors, Frictionless Flexures, High-Speed Piezoelectric Drives
