Temperature transmitters
Nov. 25, 2013
The TD Series temperature transmitters feature a one-piece, stainless-steel housing to meet 3A standards for food and beverage applications and for use in harsh industrial applications. The integrated transmitter electronics, process connector, and Pt1000 Class “A” RTD probe are laser-welded, IP69K sealed.
The two-wire loop-powered transmitter is prescaled for ranges of 0…100°C and 0…300°F. Applications requiring different ranges can be scaled with a programming tool via IO-Link.
The transmitter’s highly engineered tip design reduces thermal mass and precisely locates the RTD element with a constant position and force, providing reaction speeds of 1 sec to 50% and 3 sec to 90% of temperature change.
Available probe lengths are 30, 50, 100, and 150 mm. The units are available with 1.5 or 2-in. tri-clamp fittings.
ifm efector inc., 782 Springdale Dr., Exton, PA 19341, (800) 441-8246, www.ifm.com/us
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
