The SPCS Version 2 (SPCS-2) is a high-flow servopneumatic control valve that provides electriclike closed-loop motion control when used with direct feedback pneumatic actuators.
The system eliminates the need to change manual switches or adjust rotary potentiometers during system setup. System configuration and setup is through a standard USB connection and the company’s SPCS-2 software. Features of the SPCS-2 make it easy to use pneumatic motion control positioning for payloads up to 450 lb and velocities up to 15 ips
Bimba Manufacturing Co., Box 68, Monee, IL 60449, (708) 534-8544, www.bimba.com
Safety Products Overview
Dec. 20, 2024
