Signal conditioners
Oct. 28, 2013
Signal conditioners
The DRSP-I Series of dc-current signal splitters feature one 4-to-20-mA input to two 4-to-20-mA outputs with full isolation. Each input has zero and span adjustments. Features of the splitter include an output test button for each channel; built-in loop power supplies for sink/source I/O; split, convert, boost, and rescale process signals, and the ability to interface a process signal with multiple panel meters, PLCs, recorders, data acquisition, DCS, and SCADA systems.
Omega Engineering Inc.,One Omega Dr., Stamford, CT 06907, (800) 826-6342, www.omega.com
