Each is ball-screw driven and built on an extruded 6063-T6 aluminum base with black-anodized finish and 1045-steel side supports. C10 ball-screw diameters range from 12 to 20 mm and leads can be from 4 to 20 mm. This lets machine builders tailor actuators to the application.
Misumi USA Inc., 1105 Remington Rd., Suite B, Schaumburg, IL 60173, (800) 681-7475, misumiusa.com
Aug. 29, 2024
Aug. 28, 2024
