For optimal results, attention should be paid to the proper adjustment and monitoring of the press-in force when using a gas compression spring. The force-controlled setting process is highly recommended, especially for fasteners with internal threads (clinch nuts)—assuming that the spatial conditions in the tool enable the installation of a gas compression spring.
The work of the press operator can be simplified and sped up considerably with the use of a force-controlled system. During press setup, the operator only has to focus on the sheet metal. Subsequent fine-tuning with a view on the produced sheet metal joints is not required. That means shorter downtimes of the press and much faster startup.
A force-controlled system provides constant clinching results and consistent quality of the sheet metal connection. Uniform performance of the fasteners is ensured. The run-in speed of a tool is increased and a higher output, with higher quality and lower unit costs, can be achieved.
Elias Herb is online marketing manager for MDS Autoriv.
