Panel PC - B+R Industrial Automation Corp.,
Oct. 7, 2010
The Panel PC 800 covers a range high performance applications.
The Panel PC 800 covers a performance range from energy-efficient Intel Atom N270 processors to Core2 Duo processors for applications with the highest performance requirements. The 15‑in. XGA and 19-in. SXGA touchscreen displays provide a simple and intuitive user interface.
The unit’s Atom 1.6-GHz processor provides 3-Gbyte SDRAM for fast processing of memory intensive programs. The Dual Core processors are for applications that place high demands on computing power. The Core2 Duo CPUs and Core2 Duo T9400 2.53-GHz processors, with the new GM45 chipset are available. The Panel can be operated with the Core2 Duo processors without a fan. The chipset, processor, and other components are connected directly to the heat sink using heat-conductive materials.
B+R Industrial Automation Corp., 1250 Northmeadow Pkwy., S-100, Roswell, GA 30076, (770) 772-0400, www.br-automation.com
© 2010 Penton Media, Inc.
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
