Vertical lift stage - Aerotech Inc.
Sept. 9, 2010
The ANT130-5-V is a linear-motor-driven wedge-style vertical lift stage that offers 5-mm travel.
The ANT130-5-V is a linear-motor-driven wedge-style vertical lift stage that offers 5-mm travel. The stage, designed for stand-alone use, can also be used with other stages for multiaxis positioning.
The units feature advanced direct-drive technology and anticreep crossed-roller bearings. The lack of hysteresis or backlash provides accurate and repeatable nanometer motion. The stage’s drive and bearing combination offers advantages in disk-drive fabrication, fiber alignment, optical-delay-element actuation, sensor testing, and scanning processes.
Aerotech Inc., 101 Zeta Dr., Pittsburgh, PA 15238, (412) 967-6854, www.aerotech.com
© 2010 Penton Media, Inc.
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
