A piston-type flow switch warns patients on dialysis machines of interruptions in flow. The magnetic piston in the new FS-W switch from Gem Sensors Inc. in Plainville, Conn., moves in response to flow and actuates a hermetically sealed reed switch isolated within the plastic body. A stainless-steel spring deactivates the switch when flow decreases. The switch gives users positive flow and no flow indications to accurately identify any interruption of flow during dialysis. The previous switch, a thermal-dispersion flow sensor, was a source of maintenance problems and high repair costs. The sensor couldn't accurately detect fluid flow, caused unwarranted alarms, and eventually shut down the machine.
March 18, 2025
March 18, 2025
March 18, 2025
