High-Power Connectors
May 10, 2007
The M40 Powerfast connectors handle motor applications up to 600 V and 55 A to provide power to a 30-hp dc motor or 55-hp 3f ac motor.
The M40 Powerfast connectors handle motor applications up to 600 V and 55 A to provide power to a 30-hp dc motor or 55-hp 3f ac motor. The cordset may be 100% cable-and-connector shielded against RFI and EMI by attaching a braid shield directly to the coupling nut. All connectors provide IP67 protection.
Turck Co., 10249 Yellow Circle Dr., Minnetonka, MN 55343, (800) 544-7769, turck.com
