Squeeze Handle Permits One-Hand Actuation
June 5, 2015
The AC-50 Squeeze Handle Actuator enables one-hand squeeze operation.
The AC-50 Squeeze Handle Actuator from Southco Inc., Concordville, Pa., enables one-hand squeeze operation. It features an ergonomic, curved profile specifically designed for easy mounting to tubular frames and curved structures. For example, when mounted on ladders of large off-highway vehicles, it lets operators easily release a door mechanism while keeping both hands on the ladder—safely opening the door and helping eliminate a potential falling hazard.
A cable connects the AC-50 to an R4 rotary latch, creating a reliable remote-latching mechanism. And when the actuator mounts to a tube, the cable can be concealed inside of it and easily routed to the latch, enhancing security.
The actuator measures about 6.6 in. long, 1.7 in. high, and 1.1 in. wide; is made of high-strength, corrosion-resistant glass-filled nylon; and is tested to 40,000 cycles. It is suited for both indoor and outdoor use in construction equipment and RVs, as well as in marine, industrial, and other applications.
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
