Dc compressor
Sept. 12, 2013
The 135 Series DC WOB-L lightweight dc compressor is designed for air seats, light-duty air suspension, and other mobile applications. The lightweight, intermittent-duty pump weighs 1.16 lb and measures 3.6 × 1.66 × 4.34 in. Available in 12 or 24 V, the unit features an oil-less piston and cylinder, stainless-steel and silicone valves, a built-in inlet filter. It is balanced for smooth, low vibration, and resists dust and moisture.Thomas Div., A Gardner Denver Co., 1419 Illinois Ave., Sheboygan, WI 53081, (920) 457-4891, www.gd-thomas.com/productlist.aspx?id=24695&tp=p
