Hall Sensor Measures 360 Deg. of Rotation (.PDF Download)
Oct. 27, 2016
Engineers who want to measure and control rotating antennas, fluid flow direction, or a robotic arm joint can now use a Two-Pi hallpot angle sensor from Elweco Inc., Painesville, Ohio, to measure the angular rotation of a shaft or joint. The sensor can measure...
Register or sign in below to download the full article in .PDF format, including high resolution graphics and schematics when applicable.
