Cool Down Electronic Devices and Recover Waste Heat
Today’s generation of electronics are super-powerful—we run our smartphones for long hours, crunching terabytes of data and even play Minecraft on our laptops. But using electronic gadgets for extended periods of time can cause them to overheat, slow down or even damage components.
Researchers have developed a hydrogel that promises to both cool down electronics and convert their waste heat into electricity.
Reporting in the American Chemical Society’s journal, Nano Letters, the researchers said they wanted to design a “smart thermogalvanic hydrogel that could convert waste heat into electricity, while also lowering the temperature of the device.” Scientists have developed devices that can do one or the other—but not both simultaneously, they noted.
How it Works
The hydrogel, which is made of a polymer (polyacrylamide framework) infused with water and ions, generates electricity when it is heated. This occurs when two of the ions—ferricyanide and ferrocyanide—transfer electrons between electrodes, note the researchers. At the same time, a cooling effect occurs when water inside the hydrogel evaporates. After each use, the hydrogel is regenerated as it absorbs water from the surrounding environment.
To demonstrate how the material works, the researchers attached a hydrogel film to a cellphone battery. They were able to decrease the temperature of the battery by 68°F (20°C). The waste heat was converted into five microwatts (5μW) of electricity.
The reduced working temperature ensures safe operation of the battery, and the electricity gathered is enough for monitoring the battery or controlling the cooling system, the researchers said.
Rehana BeggRehana Begg
As Machine Design’s content lead, Rehana Begg is tasked with elevating the voice of the design and multi-disciplinary engineer in the face of digital transformation and engineering innovation. Begg has more than 24 years of editorial experience and has spent the past decade in the trenches of industrial manufacturing, focusing on new technologies, manufacturing innovation and business. Her B2B career has taken her from corporate boardrooms to plant floors and underground mining stopes, covering everything from automation & IIoT, robotics, mechanical design and additive manufacturing to plant operations, maintenance, reliability and continuous improvement. Begg holds an MBA, a Master of Journalism degree, and a BA (Hons.) in Political Science. She is committed to lifelong learning and feeds her passion for innovation in publishing, transparent science and clear communication by attending relevant conferences and seminars/workshops.
YouTube: @MachineDesign-EBM
Related
