Screaming off the tee
April 14, 2005
The newest drivers use aerospace materials and unconventional weighting to deliver distance and accuracy.
Kenneth Korane
Managing Editor
TaylorMade's r7 quad features four movable weights for adjusting club CG and ball trajectory. The cartridges install with a special six-point-drive torque wrench.
The Srixon W-403AD has varying wall thicknesses throughout the clubhead. The construction lets the entire clubhead deform on impact, said to launch the ball in a high trajectory with low spin.
The King Cobra 454 Comp is designed for players of all skill levels seeking a combination of distance, forgiveness, and accuracy. At 454 cm3, the model features the largest "sweet zone" of any King Cobra driver.
The Wilson Staff Dd5 combines a lightweight carbon-composite crown with a titanium base. A large 460-cm3 head gives better results on offcenter hits.
Of all the weapons in a golfer's bag, the driver offers the most power and distance off the tee. But it's notoriously difficult to hit and control where the ball lands. This has golfers on a never-ending quest to find the elusive club that will magically combine long drives with pinpoint accuracy.
One hurdle is that golfers often don't strike the ball where they're supposed to — in the center of the clubface. Another is that no two players have exactly the same swing. To overcome these shortcomings, club designers increasingly rely on advanced materials to match mass-produced clubs to individual swings.
Shifting Weight
The new r7 quad ht titanium driver from TaylorMade Golf, Carlsbad, Calif., gives users the freedom to change the clubhead's weight distribution and create the best impact conditions for an individual golfer's abilities.
Typical drivers deliver a single set of "launch" conditions — the clubhead's angle, pitch, and weighting as the face impacts the ball. If those conditions are not ideal for a particular swing, however, the player sacrifices distance and control. TaylorMade Launch Control (TLC) technology is said to help overcome less than ideal swings.
TLC repositions 48 gm of weight within the head by including four ports that hold four movable weights: two 2-gm titanium cartridges and two 10-gm tungsten ones.
Installing cartridges in different configurations shifts the clubhead's center of gravity to different locations. Each of the six possible CGs changes the trajectory that helps players hit balls higher or lower, and adjusts the ball's flight to the right or left by up to 10 yd.
A key challenge posed by TLC was freeing up 48 gm of discretionary weight from within the 400-cm 3 clubhead. Part of the solution was to use high-strength titanium that reduced wall thickness without sacrificing durability. The r7 quad driver has 0.8-mm walls versus 1.0 to 1.2 mm in typical titanium drivers.
Another weight-saving feature is an inverted cone milled onto the inner side of the cold-rolled titanium clubface. It is said to increase the portion of the clubface that delivers a coefficient of restitution (COR) greater than 0.80. The U.S. Golf Association's COR test measures the springlike effect of the clubface. USGA rules limit the rebound speed of a ball striking the clubface to no more than 0.83 of impact speed. The inverted cone lets a larger area of the face deliver high-ball velocities, resulting in longer drives even on off-center hits. It also lightens the clubface, and the saved weight was invested in the TLC ports and cartridges.
Varying Thickness
The W-403AD driver from Norcross, Ga.-based Srixon Sports features a proprietary design where not only the face, but the sole and backwall of the driver vary in thickness.
According to company officials,-many drivers on the market have a "sweet spot" that gives the ball a rebound velocity right at the USGA COR limit. The key to modern driver design, they say, is maximizing the high-COR zone across the face for good distance even on off-center hits.
In the W-403AD's Impact Power Body, the face, sole, and backwall all work together, letting the entire clubhead deform at impact. This controlled deformation keeps the ball on the clubface fractionally longer, compared to other drivers. This is said to take advantage of the aerodynamics and rebound characteristics of modern golf balls, resulting in high trajectories and low spin for maximum distance.
The head is made of a thin, forged titanium face with a precision vacuum-cast titanium body.
Clubface thickness varies in three places, which maximizes energy transfer across a large, high-COR zone. The zone's elliptical shape extends from the high toe to the low heel, consistent with the strike patterns of most golfers.
A low center of gravity reportedly ensures stabilityat impact. And the company moves the CG progressively towards the heel as lofts increase, making higher-loft drivers easier to square at impact for slower-swinging recreational players.
The MacTec NVG driver from MacGregor Golf, Albany, Ga., carries a clubhead and weighting system the company claims will increase distance, forgiveness, and accuracy, regardless of skill level.
The NVG features a thin, 0.4-mm 15-3 titanium crown silver brazed into a 6-4 titanium body. This effectively shifts weight from crown to sole and dramatically lowers the center of gravity for higher launch, less spin, and more distance.
Drivers with 7.5 and 8.5° lofts have harder 15-3 titanium face inserts for highimpact response and low spin, which should provide more roll and distance. A higher-elongation titanium face insert is used in 9.5, 10.5 and 11.5° lofts for more flexing and rebound across the entire face and better results on off-center hits. Four tungsten weights totaling 19 gm mount in the heel and toe. Eight and 6-gm weights in the heel create a low, deep CG to improve launch properties the tendency to slightly draw the ball. Two 2.5-gm weights, one each in the extreme heel and toe make the clubhead more stable.
Composite Construction
King Cobra Comp drivers from Cobra Golf, Carlsbad, Calif., rely on a carbon-composite top and titanium body. Replacing heavier titanium with a lightweight composite crown shaves up to 15 gm off the top of the club, depending on head size. This allows for larger faces and heads as well as a lower, deeper center of gravity.
Two weights are precisely positioned in the head to promote a high launch angle, low spin rate, and ball flight biased to the left. Weighting varies by model to optimize trajectory and spin for individual-players.
The large face flexes with the goal of generating longer, more-accurate drives. A milled-titanium rhombus-shaped insert within the face increases flex at impact on both center and off-center hits, according to the company. This equates to greater ball speed and a larger sweet spot.
Cleveland Golf, Cypress, Calif., and Wilson Sporting Goods, Chicago, have introduced the Launcher 460 Comp and Wilson Staff Dd5, respectively. Both are 460 cm3, multimaterial drivers that combine the benefits of lightweight carbon-fiber composite with the strength of titanium. The extra-large clubfaces offer more forgiveness on off-center hits.
Composite crowns let manufacturers distribute weight lower and deeper around the clubhead perimeter. This lowers the CG and puts it further away from the face, which should produce drives with the sought-after high launch and low spin and expand the sweet spot.
The Launcher includes additional perimeter weighting that increases resistance to twisting on off-center shots. Engineers at Cleveland Golf have also used analysis and testing to improve acoustic characteristics so the driver generates a more solid-sounding impact — reportedly a drawback with most multimaterial drivers.
Wilson's Staff Dd5 has an ultrathin face for maximum COR and is plasma welded for a thinner bead than with standard welds. This further reduces unwanted weight that once again can be transferred deeper in the clubhead for the desired low center of gravity. In addition, weight pads on the rear sole precisely position the center of gravity in line with the high-COR face, working together to generate longdistance drives.
DRIVE FOR $HOW
r7 quad ht $600 Launcher 460 Comp $479 King Cobra Comp $450 MacTec NVG $449.99 Redline RPM 430Q $449.99 Srixon W-403AD $399 Wilson Staff Dd5 $300
The latest drivers carry a hefty manufacturer's suggested retail price.
MAKE CONTACT
Accu-Length
acculength.com
Adams Golf
adamsgolf.com
Cleveland Golf
clevelandgolf.com
Cobra Golf Co.
cobragolf.com
MacGregor Golf
macgregorgolf.com
Srixon Sports USA
srixon.com
TaylorMade Golf Co.
taylormadegolf.com
Wilson Sporting Goods Co.
wilsonstaff.com
Shifting Weight Drives Ball Straight
The new Redline RPM 430Q from Adams Golf, Plano, Tex., a 430-cm 3 titanium driver with a carbon-composite crown, features a series of adjustable weights.
The company's RePositioned Mass technology distributes 44 gm of clubhead weight, including two 10-gm and two 2-gm screws that mount in four 5-gm ports along the lower perimeter. Positioning ports low along the clubhead perimeter is supposed to add forgiveness on mis-hits.
Putting the 10-gm weights in the interior ports produces a high launch angle and ball trajectory with little movement left or right. Moving them into the outer ports yields a lower, straight trajectory. Weighting the heel produces a draw, with the ball curving to the left.
In similar fashion, moving more weight to the toe makes the ball curve, or fade, to the right.
Weights can be positioned in six different configurations to adjust launch angle and spin rates, and customize trajectory and ball curvature for the best distance and accuracy. This lets players tailor the club to course or playing conditions and compensate for deficiencies in their swings.
Clubs Grow With The Kids
The Accu-Length system was an award winner for innovative design at the recent PGA Merchandise Show. A series of locking spacers permits gradual increases in shaft length.
For parents of young duffers, it can be expensive investing in new clubs with every growth spurt. An alternative, Accu-Length clubs, uses a spacer system to gradually increase club length. Shaft length can increase 1 in. for approximately every 21/2 in. the child grows.
The clubs feature two-piece, filament-wound shafts connected by aluminum spacers that twist and lock in place with a lefthanded thread. Thus, they tighten every time a golfer hits the ball, and no set screws or other fasteners are needed. Stainless-steel clubheads instead of low-grade zinc alloys used in many children's clubs provide strength and durability.
Club rigidity increases with the number of spacers, structurally benefiting the growing junior golfer. Loft and distance grow approximately 10 yd per additional spacer for a 60-mph swing speed, due to added swing weight and longer length. The two-piece shaft reportedly minimizes head torque, and the spacers damp vibrations when mishitting a golf ball.
Kenneth Korane
Ken Korane holds a B.S. Mechanical Engineering from The Ohio State University. In addition to serving as an editor at Machine Design until August 2015, his prior work experience includes product engineer at Parker Hannifin Corp. and mechanical design engineer at Euclid Inc.
