Linear Labeling System Reaches Output of 400 Units per Minute
On display at Onelite’s Booth (#450) at Pharma Expo, a division of Pack Expo, the AR-Box is a high-speed, automatic linear labeling system designed to apply self-adhesive labels or tamper-evident seals tuck flap cartons on upper and/or bottom faces of closed boxes.
Machinedesign Com Sites Machinedesign com Files Uploads 2014 11 Onelite Web
On display at Onelite’s Booth (#450) at Pharma Expo, a division of Pack Expo, was the AR-Box, a high-speed, automatic linear labeling system designed to apply self-adhesive labels or tamper-evident seals tuck flap cartons on upper and/or bottom faces of closed boxes. Manufacturers can add printers and data capture of traceability information with e-Pedigree and sterilization systems, without to the need to add a mass amount of additional space to the productivity line. It is controlled by a PLC with a touch screen, thin film transistor (TFT) 7-in. display and can incorporate up to three labelling heads, reaching a maximum output of 400 units per minute. The system is ideal for pharmaceutical labs that need to comply with changing traceability laws but don’t want to upgrade existing packaging lines.
