Angular grippers
July 11, 2013
Low-cost angular grippers handle small parts in confined areas. Choose from four bore sizes — 10 to 25 mm. The grippers feature magnetic pistons that allow “open” and “close” position sensing with optional sensors located in slots along the body. Lubrication is not required. Hard-coated aluminum body insures abrasion and corrosion resistance. Catalog #FKA-09.Fabco-Air Inc., 3716 NE 49th Ave., Gainesville, FL 32609, (352) 373-3578, www.fabco-air.com
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
