Manual pin inserter
The Model PMH pin-installation machine is suited for low-to-moderate production volumes that require high insertion force. The flexible machine accommodates quick changeovers by simply changing the pin-driving chuck and replacing the fixture at the base of the machine to adapt to the specific application and pin size being installed. The precisely machined rack and casting results in smooth operation, precise positioning, repeatability, and durability.
SPIROL International Corp., 30 Rock Ave., Danielson, CT 06239, (860) 774-8571, www.SPIROL.com
