The New Generation SM5 universal tension meter measures the Hertz frequency of all belt types, regardless of the belting and tension-member material. The meter provides a belt-frequency reading of 7 to 450 ±5 Hz. Belt pretensioning maintains tension at all times by eliminating belt under or overtensioning.
The New Generation SM5 universal tension meter measures the Hertz frequency of all belt types, regardless of the belting and tension-member material. The meter provides a belt-frequency reading of 7 to 450 ±5 Hz. Belt pretensioning maintains tension at all times by eliminating belt under or overtensioning. Ensuring correct belt tensioning provides optimal belt performance and life; saves production and downtime with quick readings; fulfills quality-system requirements with traceable certification; and works with the company’s online calculation program.
