NASA ion thruster sets endurance record
Sept. 12, 2013
Engineers assemble the NASA Evolutionary Xenon Thruster (NEXT) before it begins its 5.5-year endurance test. The thruster generates small amounts of thrust using xenon gas that is ionized and accelerated by electricity as the propellant.
NASA’s Evolutionary Xenon Test thruster (NEXT) recently finished operating for over 48,000 hr, or 5.5 years, in a vacuum chamber at the Glenn Research Center in Cleveland. It set a record as the longest test of any space-propulsion system. Over that time, the engine, which was partly built by Aerojet Rocketdyne, Calif., consumed 1,918 lb of xenon while generating thrust that would take a conventional chemical rocket engine 22,000 lb of propellant to create. Engineers at Glenn Research Center designed and constructed the engine’s core ionization chamber. NEXT constantly put out 236 mN of thrust, enough to accelerate a 1,000-kg satellite in space at 0.000236 m/sec2, which works out to an additional 20.4 m/sec added every day.
An ion thruster first creates ions by bombarding the propellant, in this case xenon, with electrons. The ions are then accelerated out the back by negatively and positively charged grids with precisely drilled holes or electric optics drilled through them. A neutralizing cathode gives the ion stream a neutral charge, ensuring the spacecraft doe not build up a large positive charge over time as it continually ejects negatively charged particles.
The thruster works by using electricity to ionize xenon, then accelerating those ions out the back of the engine using electric fields and thereby generating thrust. Ion thrusters will not work in Earth’s atmosphere due to the presence of too many ions, so they can only be used in the vacuum of space. This limits them to station keeping and long, unmanned, intrasolar-system travel, tasks that need not be done in a hurry. But ion thrusters are more efficient than conventional chemical rockets, getting 10 to 12 times more thrust out of each pound of propellant. Ion thrusters are usually reserved for spacecraft with solar cells, which generate electricity without expensive or heavy fuel.
NEXT fires away, generating about 236 mN of thrust and consuming 1,918 lb of xenon over more than 48,000 hr of continuous firing.
The main goal of the NEXT program was extending the service life of ion thrusters. The devices create high-energy ions which degrade and damage metal components by sputtering away the metal. The effect is pronounced in two-electrode or dual-grid thrusters, such as NEXT. The grids are oppositely charged and xenon ions accelerate out the rear, passing through a pair of holes precision-drilled in each grid. The holes act as optics to electrically focus the beam of ions for maximum thrust. Over time, ions eat away at the grids and the hollow cathode that creates the ions, lowering efficiency and eventually leading to failure. Advancements in computer modeling, hollow-cathode technology, and improved optics let NASA significantly extend the life of NEXT, as shown by the recent multiyear test.
NASA engineers built the first working ion thrusters at the NASA Lewis Research Center (now Glenn Research Center) in the early 1960s.
Future development will concentrate on getting thrusters to operate at higher power and speed levels, and for longer durations. Engineers also want to make the thrusters lighter, more compact, and more reliable by using carbon-based ion optics and electron cyclotron resonance which uses microwaves to generate an ion-creating plasma.
Resources: Aerojet Rocketdyne, NASA Glenn Research Center
Videos made at NASA Glenn Research Center
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
