Actuators lift and lower EQ-36 radar
June 9, 2011
Exlar actuators lift and lower EQ-36 radar
Resources:
Exlar Corp.
Lockheed Martin’s new EQ-36 radars track incoming mortars, artillery shells, and rockets, and then calculates where they were fired. The radar, which can scan 360° or a 90° section of sky, uses a pair of linear actuators from Exlar Corp., Chanhassen, Minn., to raise and lower the radar’s antenna into position. Each actuator uses a roller screw mounted inside a telescoping tube to generate linear motion. The radar is being used in Iraq and Afghanistan.
© 2011 Penton Media, Inc.
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
