Small UAV can take off and land vertically
Oct. 6, 2011
Resources:
AeroVironment
For more information on the company’s other military UAVs
After four years of R&D, engineers at AeroVironment Inc., Monrovia, Calif., have successfully test flown their Shrike UAV, a 5-lb drone that can fit in a backpack and take off and land vertically. Built under contract from DARPA, the Shrike can hover or fly for more than 40 min while transmitting high-resolution encrypted video back to a home base. It also has enough battery power to land on the top of a building or cliff, for example, and transmit several hours of video of what it is looking at, a capability the Pentagon calls “perch and stare.” The battery-powered aircraft is remotely flown using the same ground-control system used to pilot the company’s other UAVs, including the Raven, Wasp, and Puma.
© 2011 Penton Media, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
