Sponsored by
Rockwell Automation
Contemporary control systems scale to match the size and complexity of an application, putting OEMs and manufacturers on a pathway to a single control and information architecture. Learn how scalability can help reduce the costs and complexities of a machine in this new white paper on the Midrange Architecture System from Rockwell Automation, designed for applications with 16 axes or fewer that require the same high-performance motion control over EtherNet/IP as larger systems.
Web site: download whitepaper
