Cable-tie brackets
July 11, 2013
The all-in-one “pneumatically nailed” TackMounts secure cabling,tubing, and wiring-harness applications. The brackets are more permanent that adhesives and faster, safer, and cleaner than drilling. TackMounts are made of high-strength, impact-resistant polyamide (nylon) with a built-in hardened-steel MetalTack that securely nails into virtually any metal surface. The brackets rotate in place for final alignment making harnessing tasks a snap.Gripnail Corp., 97 Dexter Rd., East Providence, RI 02914, (800) 474-7624, www.gripnail.com/tackmounts.html
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
