Machinedesign Com Sites Machinedesign com Files Uploads 2013 06 Dymax Dg Ece Series
UV light-curing flood lamps
June 3, 2013
The ECE Series UV light-curing flood-lamp systems optimize safety and convenience for process-controlled adhesive cures. The powerful UV lamps ensure fully cured products and fast cure times. The bulbs offer consistent intensity, are warranted for 2,000 hr, and are CE marked for worldwide use.
The light sources are capable of curing adhesives, coatings, and inks, and are ideal for curing parts with large bond lines or for simultaneously curing multiple parts in trays. The modular systems consist of a power supply, reflector housing, and 400-W metal-halide UV-curing bulb. With the addition of accessories such as UV shielding, shutter assemblies, and mounting stands, the lamps can be used as either turnkey bench-top systems or integrated into an automated assembly process.
Dymax Corp., 318 Industrial Lane, Torrington, CT 06790, (860) 482-1010, www.dymax.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
