Machinedesign Com Sites Machinedesign com Files Uploads 2013 06 Hernon Dg Autobonder
Adhesive-dispensing equipment
June 3, 2013
The Autobonder 2700 adhesive-dispensing equipment mixes two independently dispensed adhesives within the dispensing syringe, increasing efficiency and reducing waste by mixing and dispensing only the quantity needed.
The unit’s control system lets users mix infinite ratio combinations, such as 2:1, 5:1, and 10:1. A user-friendly color touchscreen lets users dispense the adhesive with metered volume precision — in shots or continuous, or automatic and manual dispense functions for jog, purge, etc.
Features include infinite mixing ratio control; remote start/stop; standard low-cost disposable static mixer tips; programmable snuff back dispense control; timer, volume, or continuous dispense modes; metered volume precision/shots and/or continuous; programmable surface matching volume/dispense speed; precision dispense mixing within microliters; portable bench-top system; auto dispense sequence/or foot switch initiate; standard 2 × 3 gallon 316 SS reservoirs; power input 90 to 240-Vac 50/60-Hz single phase; and compatible with two parts systems from 5 to 14,000 cp.
Hernon Manufacturing Inc., 121 Tech Dr., Sanford, FL 32771, (877) 554-4644, www.hernon.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
