This article was updated April 3, 2023. It was originally published June 7, 2016.
RELATED
Structural Properties of Bolted Joints
What’s the Difference Between Bearing, Shear, and Tear-Out Stress?
An Introduction to Lean Bolting
The Preload Matters…A Lot
Workers often tighten bolts to 75% to 80% of the bolt proof load. This works for many joints, but in some cases, external tensile loads reduce bolt clamping forces to zero. Something other than the 75% or 80% rule of thumb is needed.
The external tensile force needed to reduce clamping to zero (within the bolt’s and cramped parts’ elastic limits) is determined by:
(Fe/FPR)0 = (Fb/FPR)0
= ((1+r)/r)(Fi/FPR)
where r = Kp/Kb, Kp is the clamped part’s spring constant (lb/in), and Kb is the bolt’s spring constant (lb/in); Fe is the external load on the joint (lb), FPR is the bolt proof load (lb), Fb is bolt load (lb); and Fi is bolt preload (lb). The subscript “0” identifies a value at zero clamping load. This equation can be used to calculate the maximum force that can be applied to a specific joint without the parts separating.
For common values of r, the force can determined from the graph below, which is based on the equation.
