LED Pilot Lights
June 23, 2014
LED Pilot Lights
Designed for applications that require accurate recognition, regardless of external conditions, AP22M pilot lights use high-intensity LEDs to provide ultrabright visibility, even in direct sunlight. The lights now have new voltage options — 12 Vdc, 24 Vac/dc, or 120 Vac. Their optical design makes them twice as bright as standard pilot lights when viewed from the front and up to 100 times brighter when viewed from the side.
The lights are available in red, green, yellow, amber, blue, and white with a choice of colored lenses or a clear lens for increased contrast between on and off. AP22M pilot lights have a unibody design and integrated terminal cover with IP20 finger-safe screw terminal connections.
IDEC Corp., 1175 Elko Dr., Sunnyvale, CA 94089, (800) 262-4332
