How to Avoid Overengineering Composite Parts (.PDF Download)
Aug. 8, 2013
Composites, or fiber-reinforced plastics (FRPs), give engineers a palette of options for replacing conventional low-carbon steel with lighter, more-efficient material. At the same time, these combinations of epoxy resins and carbon or glass fibers create ...
Register or Sign in below to download the full article in .PDF format, including high resolution graphics and schematics.
