Tubing and fittings
April 26, 2012
New models of tubing and fittings have been added to the NITRA line of pneumatic components
New models of tubing and fittings have been added to the NITRA line of pneumatic components. Available in 100 and 250-ft lengths, NITRA 16-mm polyurethane tubing has a Shore A 98 hardness rating, provides tight OD tolerance, and has good kink resistance. The ether-based tubing provides hydrolysis, oil, and cold resistance, and comes in four colors.
NITRA brass adapter fittings and plugs come in 10 styles to meet pneumatic applications such as air, water, oil, oxygen, nitrogen, and argon. Made from yellow-brass bar stock or forgings, the fittings withstand pressures to 800 psi. Designed with NPT threaded connections, male and female connectors are available in ¹/ˆ to ½-in. sizes, in either two-pack or five-pack quantities.
AutomationDirect
3505 Hutchinson Rd.
Cumming, GA 30040
(800) 633-0405
www.automationdirect.com/pneumatic-parts
© 2012 Penton Media, Inc.
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
